I did follow the instrucitons. I didn't add salt in the brackish water as I didn't always know when it was brackish or not. I did check the voltage going into the unit with a VOM meter at the feed wire to the unit and know it has enough voltage. I didn't flush out the Muratic acid with fresh but flushed with harbor water.
Calling Vic would be wonderfull if I was in the US but where we are now even Skype doesn't work the best. But if what you offer doesn't help further when we get to a good connection or a new phone card in Panama I'll call him.
Thanks
Dave
Go Slow
Sail Far
Stay Long
