See the right hand column on page 2 of the manual:
solid red - is a blown fuse
1 blink per second means the electrode pack either needs cleaning (unlikely from what you've said), or has gone TU and has to be replaced.
2 blinks per second - means low voltage...check your connections and battery condition.
If you can't call Vic, email him: vic@raritaneng.com He DOES answer!
