Return to Index
Read Responses
agreed, add a strop and move the block back one.
In Response To:
Use a Spectra Strap -- the toe rail won't get chewed-up and it shold work.
American Rigging Supply, Inc. Home Page
Spinnaker sheet block for aluminum toe rail ?
Just make sure that the underside of...
The strop would work.
Bale on cheek block...
Hi Brian & all
Max...
Looks like the wrong block for that application, to me...
Gotta agree with Jon on the "wrong block" idea...
I didn't notice the block was that far back
I doubt your ratchet block has the strength of that snatch block....
You're probably right, but I'm not using it as a turning block...
Thanks all, good discussion
