Return to Index
Read Responses
What other instruments? Where do you sail (or intend to)? How do you intend to use the autopilot (under just motor, or.
In Response To:
Autohelm 5000 Replacement
A lot depends on how you intend to use the autopilot in order to make a recommendation for you.
Almost any below deck
A guess and a thought
Before you throw it away..
Great Info
A few parts available...
Parts & Ohms
Manual
Different Manual
OK, you've got a good compass....
Correction - Autohelm 6000!
another picture
The drive unit
OK, you have a pre 1985 unit...
Sounds about right
Compass Ohm Readings - Troubleshooting
