I have this one also. No problems with priming even tho it is mounted at the top of the tank, which IMO is where you want it. I am on my second one tho as the original one began leaking from a seal this season earlier. There is a rebuild kit available and I plan to rebuild the original over the winter. Performance seems ok to me although durability is in question.
