If the SeaFrost worked for all these years, ...
then it must be okay not to mount the compressor on the engine. At least for your setup. Ours hangs off the 'beke and it makes a PITA of reaching the raw water pump (even with a SpeedSeal). But I like the holding plate and we usually need the engine once or twice a day, heading to a new harbor, so there's no wishing we had a 12v unit. As SG asked, what are you swapping the SF for?
