You might consider
In Response To: On a bulkhead installation ()
Since it is mounted off the engine you might want to add an idler arm to the situation. Then the belt would not be tension by it's approximate location from the engine but the arm would tenision the belt. Then as the engine moves the arm will constantly readjust.
Go Slow
Sail Far
Stay Long
