Return to Index
Read Responses
Thanks Tom, sounds like I'm looking for a solution without a problem :-;
In Response To:
I don't have any bleeders on my cooling circuit Max.
Bleeding air from liquids lines
What type of heater takes a Racor Filter?
Refleks, Sig, Dickenson all specify a filter
Does it use a "measuring pump"?
These are just gravity fed, regulated drip burners
Then, please excuse my ignorance
I think he has two systems, Randy
Roger that, two different heaters
The heater that runs off the engine coolant circuit is easy...
Bleeder Valve -- As in automotive heater coils
Max - a few thoughts to consider
Hi Larry, actually I'm scrapping my HW exchanger
