Jerry you should also rule out other possibilities, such as TMJ
In Response To: Meniere's Disease for Sailors ()
Many people are mis-diagnosed for other conditions which might actually be caused as a direct result of a TMJ problem. The TemporoMandubular Joint (TMJ) is enervated by nerves that branch from the same main nerve bundle that enervates the inner ear. Inflamation or pinching in the joint can transfer into the nerves and result in inner-ear symptoms.
I have a close relationship with Dr. Janet Levine, who is a specialist in diagnosing and treating this without medication or invasive surgery. She can make a diagnosis (or rule out TMJ) using equipment and clinical measurements that most ENT's and Internists don't have any education or training about. (You could hop a commuter train to Tarrytown from NYC.)
From her web site: http://www.tmjdmd.com
You may have a TMJ disorder if you have one or more of the following symptoms:
Headaches around the temples
Headaches around the forehead
Headaches at the back of the head
Headaches at the top of the head
Sinus headaches
Pain behind the eyes
Earache
Ringing in the ears (Tinnitus)
Dizziness
Jaw joint pain
Jaw joint clicking or popping
Limited opening of the mouth
Grinding teeth
Neck pain
Shoulder pain
Numbness in the fingertips
Tooth pain
