The pigment adds UV resistance
Darker colors degrade more slowly than white. This is well documented with plastic wire ties, and with nylon spinnakers. If you have a multi-colored spinnaker the white panels will always be the first to wear out and shred due to age (other than physical damage such as tearing on a spreader).
