Charlie: Let's see if I've got this straight?
In Response To: To Set The Record Straight ()
Hank Schmitt throws Herb under a bus to cover his own ass. But once that is said and out in the sailing world, he does not say anything more. Wow. What an honorable guy. You publish Schmitt's criticism, and then you follow up yourself with a article critical of Herb's routing. You quote only one source, but neglect to mention all of the folks who think that Herb does a very good job. Sounds like if a job opportunity at Pravda opens up, you should apply. You'd fit right in.
