Which you could then take off a T to your stoves line or get one long enough to go from the tank. In October, you would probably get a lot of use out of it. It's always hard to find a spot for one of these. I put ours just above the port settee. Your boat is much bigger below. It'll burn 20 hours on a bottle of CNG, right?
