everything can be controlled through the battery switch
In Response To: It has a regulator module ()
I believe the battery voltage is being sensed at the terminals, since that's where the Link connections are wired, one positive wire for each bank. Amperage is measured there also, through a shunt in a different location. I detached and reconnected the ribbon as well as both ends of the phone jack. It's not the alternator - I have a hydrometer on the boat and will check the battery
