Return to Index
Read Responses
Steve on Brendon loves his variable speed pump.
In Response To:
New Fresh water pump?
Second that. Unless you run them all at the same time, the small VSD should be fine.
Rodd, also consider a accumulator tank...
Same here.
Thought these not appropriate for VSDs?
Good question....I'll look into that...
We've had Surflo units with accumulator tanks. Service free for years.
decided on Shurflo
Make sure your wiring is the right size.
Thanks SG ! good point!
You're going to miss the Jabsco..
