Return to Index
Read Responses
Rodd, also consider a accumulator tank...
In Response To:
New Fresh water pump?
if you don't have one already....I also +1 the VSD pumps.
Steve on Brendon loves his variable speed pump.
Second that. Unless you run them all at the same time, the small VSD should be fine.
Same here.
Thought these not appropriate for VSDs?
Good question....I'll look into that...
We've had Surflo units with accumulator tanks. Service free for years.
decided on Shurflo
Make sure your wiring is the right size.
Thanks SG ! good point!
You're going to miss the Jabsco..
