I was wondering how you might tell if the voltage is low if a charger is constantly topping it off. Granted, you no doubt turn off the charger to check, but if the charger was just on, the volts are probably showing healthy.
I've had mine off the charger for 2 weeks... just to see how things look after awhile.
