Harlan Billings of Billings Marine in Stonington, ME: Spurs, hands down.
In Response To: Best Lobster Line prop cutter ()
The one caveat: A 1.25 diameter shaft has to cut the same line as 2" shaft. the worst mistake -- reduce RPM as you think you're about to hit something. If you're going to "cut it", then don't "slow punch" it.
