I do on occasion see a line or small bar between fin keel and skeg that might be effective. Usually the warp would be taught as it slides along an underbody, until it finds a niche like between keel and skeg. If the warp could be slid from keel to bottom of skeg/rudder, it would likely slide off without problems. The bolt on idea you mention sounds interesting for boats with your underbody.
