I have just acquired a nice Newport 16. I want to know what shaft length an auxiliary motor the existing bracket requires. The bracket is the standard spring-loaded 2-position type. If this info is not adequate to determine the length, then can someone tell me how to measure a motor shaft to determine the length?
