Auxiliary motor shaft length
Thanks for the great information. With the motor bracket lowered, the distance from the top of the mounting board to the bottom line of the hull is 14 inches. Looks like I can use a short shaft motor if I wish. It's only a 16 footer, so I don't really need anything but the cavitation plate and the prop in the water....
