He said that it's "rated"...
... to run up to 12 hours at 200 below max RPM". In other words, don't push it further than that for longer than that. He defined Max RPM as a variable that will change with boat loading and whether the bottom is clean; but it's just as fast as it will run flat out, then back it down 200 RPM.
Given that limit, I could run at whatever speed seems right for the circumstances without worrying too much about it.
