Wipe down after wash yesterday. Primer on 'til 'thumbprint tacky', one coat of bottom paint. Clearly needs more but this is bonded with the primer at least and the epoxy bottom is now protected from the sun. Install the bowsprit, a bit of work on the transom and the hull will be painted. It's past time....
