Hi,
thanks for the info, as it sounds like a similar job to mine.
so, to re-confirm, you sanded down the topsides, painted
where there was no non skid and put down kiwigrip to nonskid areas.
also, did you use one coat or two? the website is not quite clear on this
and a similar competitor product says two coats.
thanks again
