If you can find an 'old fashioned' paint store ...
and find that the proprietor is nearly as old as Mathesula, ask him if he can mix you some old fashioned HARD or BAR TOP varnish. A bitch to apply, needs to be flat sanded down to 1000 grit then powerbuffed with 2000 or 3000 grit .... but as scratch resistant and water resistant as a steel plate.
Spar varnish is soft because it needs to be flexible so it doesnt crack on a bendy SPAR; BAR TOP or HARD varnish isnt 'soft' and is infinitely more resistant to dings and scratches .... and spilled booze. You may have difficulty finding it or finding someone who will 'make it' for you, big box stores will have NO idea.
