Return to Index
Read Responses
Absolutely right. You make it perfect and 6 months later it's not.
In Response To:
Exactly ... excellent point Gail ...
Simple way to fill/hide bolt holes in gelcoat?
After hole filling ....
No nonskid or nonskid pattern, just smooth white gelcoat?
Glad I asked
You can always taper the tops of the holes a bit with.....
You don't need to spray it, just use a 1" chip brush
Gel-coat repair is very simple
Problem with color match is that...
I did order a base of 1/4" starboard
I did something like that for new vents.
Holy cow! Did Sabre really put those plastic cowls on?
That's why it rains in the cabin!
One of my tricks is...
LOL, great minds think alike, was thinking that too
Do you (or anyone) have a source for larger diameter truss head screws?
How about an elevator bolt?
Oh I had forgotten about those, thanks! Will check them out.
Doh, more research...
The head diameter is ample; one potential problem I see...
