Nah, just prebored with a tapered bit. The screws are just to......
In Response To: Edge joining plywood. ()
..help hold position and assist in glue joint pressure. I also used clamps on every joint for the 'real' pressure. All the joints inside will be filleted with epoxy before at least two coats sealing with epoxy.
