Compass
We have a Ritchie with a side plug and O ring. When it occasionally develops a small air bubble, I lay it on its side plug up and very carefully use an eye dropper to add oil and remove air. Usually requires moving it around very slowly to keep the hole at the highest point and repeat adding oil and removing air. Hope this helps.
