I was starting to have problems with my elbow and the doc told me it was tennis elbow. I don't play tennis but he described what usually causes it and I'm pretty sure it was the "backhand" motion from grinding winches when you push away extending the arm out. I replaced the primary winches with lower ratio self tailers and wore a brace until it eventually went away.
I hope the surgery goes well and you can get back into it soon.
