Return to Index
Read Responses
neat trick, I'll give it a try
In Response To:
Once hoses are permeated....
Groco SweetTank Odor Neutralization System
Probably wouldnt be 'non vented' or explosion proof 12 vdc motor.
Do you have a problem?
If youre gonna 'cobble' ....
I have a bit of smell at times
"pump until there is nothing" may not be the answer
Or use a warm water moistened paper towel around the hoses, then wrap with plastic wrap.
I've put deodorizer directly in the head with good results
Possible hose odor "solution"
If the problem is odor out the vent...
Peggie, nice to see your....
Agree... good to see you Peggie. BTW something Peggie passed on to me...
There's no end to new boat gizmos.
The Groco Sweetank system has been around for nearly 10 years. Tom...it's not a new "gadget."
Gadgets I think are useful, I gave this one Gizmo status, Peggy.
I think the power question is also significant
Looked it up: about 0.25 amps
Looked it up too... They sell a tank ready set up...
No, you would not have to replace the whole tank
