Return to Index
Read Responses
Good point.
In Response To:
Probably more advantage than just the reduced wiring voltage drop
Hadn't considered charge time based sunlight hours
Data point - regarding solar panels series vs. parallel
Better solar panel performance
I had a problem upping the wire gauge
Wire woefully inadequate...
Acknowledged
BTW ~50 feet is round-trip
Good point.
I am thinking more maybe going on
Blocking diodes
Same experience here
