Wire woefully inadequate...
16 to 18 ga wire running 50 ft means you are using more energy to heat copper than charge batteries. When you went to series-parallel you cut the current so the I squared R losses were cut. Even so, the wire is still too light for that amount of power. You need a way to up that wire size.
