everything I have read seems to indicate that loose footed is the preferred arrangement. Once you add Lazyjacks or equivalent, it seems like dealing with a conventional sail cover is more cumbersome which is why I like the idea of the simplicity of having the sail drop into a cover and all you need to do is zip it up. I will need to look into the Harken system to understand how this differs from the LazyJacks - thanks for your input
