Your intake for the Yanmar would 1 1/2", wouldn't it?
In Response To: Yanmar 53 HP vs Beta 50 HP ()
The fresh water discharge would be 3". In any event, I'd replace the mixing muffler. You need to be careful that installation is correct with vented loop, etc.
Do you use a Vetus exhaust flap? With your offshore cruising, I'd suggest you consider it (unless you have a side discharge).
