Nani and I think Universal also marinize that same engine. So if Beta were fo go belly up you could probably source a heat exchanger from them.
The only other marinization specific part is the raw water pump. The shaft is unique to Beta but when I rebuilt mine I bought the shaft from the pump parts dealer.
