Return to Index
Read Responses
How large is the hose diameter?
In Response To:
Thanks
You can try a stendt?
Whale Gulper 220 pump puzzle
Air bubble or Hair in the drain hose
I would say that the pump is on it's
our sump 'failed' last weekend
clogged check valve?
I believe it iss not a diaphram pump
Thanks
