Return to Index
Read Responses
I meant that Force 10 has its HQ in Washington
In Response To:
Thanks Larry
Force 10 stove fix
well put
Thanks Larry
Geez, I see them in B.C.
You're right. I'm from NY
I thought they were in Canada?
Company split a few years ago. Some in CA, some in Canada.
Think it was purchased by a French Company.
Force 10 Cabin Heater
Big change to propane
I'd do the propane conversion, IF
I agree with Larry on this. Not worth a retrofit of tanks, etc.
I had the Force 10 propane heater in the last boat...
Brought the Force 10 heater home..
Once you've had dry heat at the flick of switch, you'll never go back
Force 10 is at the curb.
