Both settees pull out to the centerline table to hold you securely(you can pin them). And they have hinged panels, as do the pilot berths, that fold up for a higher curb(good if you need the upwind berths). In our use, there's always 2 great seaberths, the downwind settee and pilot. That leaves a clear safe path fore and aft through the boat.
