4-107
In Response To: Westerbeke 4-107 problem ()
I had a 4-107 for many years in my P-39. To me, your problem definitely sounds like fuel related. Could be the high pressure fuel pump. Suggest you loosen an injector nut and crank the engine. You should see fuel weep around the nut.
