5200 bonds at 600 psi. So if it's pulling the laminate apart then the layup there is bad and ought to be repaired anyway. Heat it, and then turn the thu hull with the right wrench.
If you break the tabs off the fitting then you can grind to the point where the face joins the thru hull and pull each part out individually that way.
Ciao
