Yanmar moved the pump to the front. Mine is a 2003. I'm sure I was not the only one who complained about this awkward location. The engine mount in the picture is an after-market model. After I found out that the pump could not even be removed with the standard engine mount in place I had it swapped before the engine was installed.
