Turn the plate over
In Response To: Speed Seal life... ()
The original OEM impellers probably produce less wear. After a bunch of hours you may meted to replace the plate. You cam modify a none Speedseal plate and install it or, you can contact Speedseal. You shouldn't need to replace the whole thing.
