Return to Index
Read Responses
COOL … thanks for that Charlie, cheers, John
In Response To:
I have a 32 watt flex panel mounted on the bimini. I've used the Sunsaver
Solar Panel and Controller questions ...
600 Ah of battery
right you are. NO controller needed with that setup.
Be VERY careful...
I thought they were wet cells
some thoughts
Some quick answers
No fuse near the panels
Your point about ampacity is well taken
Larry....
Cheaper solar controller will ....
Should have said unsafe if only fuse is on the panel.
Thanks for that advice
Thanks everyone for the Solar & Controller points well taken ...
Here an 45W 26x21
Thanks Steve … looks almost identical to ...
I don't know.
