Return to Index
Read Responses
right you are. NO controller needed with that setup.
In Response To:
600 Ah of battery
Solar Panel and Controller questions ...
I have a 32 watt flex panel mounted on the bimini. I've used the Sunsaver
COOL … thanks for that Charlie, cheers, John
600 Ah of battery
Be VERY careful...
I thought they were wet cells
some thoughts
Some quick answers
No fuse near the panels
Your point about ampacity is well taken
Larry....
Cheaper solar controller will ....
Should have said unsafe if only fuse is on the panel.
Thanks for that advice
Thanks everyone for the Solar & Controller points well taken ...
Here an 45W 26x21
Thanks Steve … looks almost identical to ...
I don't know.
