It's very simple, just a right angle worm gear and a Lucas starter motor with an extra long shaft. Somewhere along the way the hardened roll pin that holds the gear to the vertical shaft was replaced with an SS bolt. That bolt came out in the shape of an S and has been replaced with a proper pin. An emergency cruising repair, I suspect.
