What do you mean "bypassed"
In Response To: original 1990 equipment ()
If you don't drain and blow-out the hot water heater of all hot water, and it has some residual water in "the tank" or piping, then you can have freeze damage? While I think the drain is "low", I'm not sure that there isn't water in the tank that will freeze, Craig?
