Return to Index
Read Responses
Are you thinking of like a 3/4" or so hole cap for over bolts?
In Response To:
How big
Is there a perfered source for the plastic headliner hole covering?
How big
Yes, Westy. I had to remove caps
I've seen them in a hardware store with a good fastener department.
Apparently called "hole plugs" as well...see link.
Yep- our local ACE has a tray full of different sizes and colors
What about these
I'm not sure what you mean, but several years ago ...
Caps
Aside from calling Sabre (so you get the same ones)
