Return to Index
Read Responses
Apparently called "hole plugs" as well...see link.
In Response To:
I've seen them in a hardware store with a good fastener department.
http://www.widgetco.com/hole-plugs
Is there a perfered source for the plastic headliner hole covering?
How big
Are you thinking of like a 3/4" or so hole cap for over bolts?
Yes, Westy. I had to remove caps
Yep- our local ACE has a tray full of different sizes and colors
What about these
I'm not sure what you mean, but several years ago ...
Caps
Aside from calling Sabre (so you get the same ones)
