Interesting setup.
The Electrodyne website has no detailed performance specs. Usually alternators are running at >3* engine RPM. What RPM do you run it at? Any problem with cooling ?
I have been thinking of something similar, except was thinking of CV joint to a jackshaft then pulley(s) to alternator and possibly water-maker pump.
Cheers,
JM.
