Get a different pump. Don't have a mesh in there.
In Response To: The only readon I can ()
Some tank pickup tubes have those. They cause recurrent un explained failures which shut the engine down, and then clear after the crud drops -- until it is sucked up again. Those filters actual mask visibly being able to note the problem in you Racor bowls.
