As confident as can be
In Response To: Very fortunate ()
It's also been in use 5 years since the incident, occasionally under some very strenuous conditions. The rigger's inspection immediately after the incident was a mast-down inspection that included removing the headstay foil to check the whole length of the wire rigging. I inspect annually and hire a rigger about every other year to go over everything carefully.
